Bath cold water 15 or 22mm pipe?
5 Jan 2006
Hi
I'm replacing my bathroom suite and have found that the sink has both hot and cold pipes being 15mm copper pipe leading to it, but the bath has 15mm cold and 22 mm hot water.
Is this normal?
If not, should i fit my new bath with 22mm cold and 22mm hot water.
Is there any benefit to having 11mm or 22mm cold water on the bath?
If so, where is best to put the 15mm to 22mm cold water connector as I am pretty sure the mains cold water is 15mm.
Thanks for the help
is the cold supplied at water mains pressure, or from a tank?
Hi
Is this normal?
Thanks for the help
If it is good enough for your old bath it`s good enough for your new one.
the cold water is at mains pressure (directly above the incoming feed into the kitchen). Does that mean 15mm is fine - but you would use 22mm from the cold water tank?
PS. I am moving the bath to a new wall so cant use the existing pipes for old bath
