My Dad called me yesterday with a fault that I cant figure out
He has a halogen exterior light which was tripping the lighting mcb when switched on, he disconected it at the switch by removing the link wire which came from the live feed to the other switch in the box - this was 10 years ago!
Yesterday he called me as he had noticed that the halogen light was glowing a dim red, he hadn't noticed it before, but I can only assume it's been like this since the fault
As the live is disconnected at the switch, I'm guessing the light must somehow be receiving voltage either via the original fault through the N, and has a very high resistance path back to earth, possibly from water ingress or suchlike?
I'm going over to sort the fault over xmas, and I'm hoping the fault will be obvious once I start investigating, but it has me a bit stumped as to what might be happening here - any ideas?
The supply is a TT
Thanks, and Merry Xmas
The supply is a TT
