I have had two new french doors fitted with side glass panels in my porchway, A rated glass all double glazed units. The porch is always open to an indoor room which has heating. I saw the damp course being fitted when the doors were fitted but I am now getting lots of moisture/condensation running down the walls directly beside these glass panels, both sides, left and right. It is so bad the carpet is now getting wet in the outer corners and even the sealant used at the sides is getting soggy. I cannot understand it as the old glass was rated C and I never had this problem before. Can anyone advise, is this an effect of the A rated glass and should I buy a dehumidifier? If so, the porchway is 13' x 2', can anyone advise the correct size and one that is quiet? Thank you for any help.
