Accenta g3 help to program program2
You can, but as mentioned earlier, you'd have to unset programme 2 and then set programme 1.
But it would work, and its all in the manual
Yeah pal no problem with the setting and unsetting just can't get my head round the programming of prog 2. Must be stupid but all sounds like gibberish when I read it. Lol
The problem with almost sticking to the default is that I only want 1 zone to be active on prog 2. So my "man cave" is covered through the day so all tools plasma and ps3 are safe ;-)
Working away. Should be home tomorrow or thurs. will count up and let u know.
Thanks for the help
zone1 front door 1 contact
zone2 living room 1 pir
zone3 dining room 1 pir
zone4 kitchen 1 pir
zone5 back bed 1 viper
zone6 shed 1 contact
man cave 3 contacts
1 dual tech
zone7 patio doors 1 viper
tried to sort prog2 only to find the git has changed the engineer code so i now cant do anything.
is it possible to reset to factory without the engineer code (i obviously have the user codes 1 and 2)
many thanks
gosh that was quick
yes i have both manuals
from what i have read the only thing i would need to change from factory settings would be the entry/exit delay we have it down to 10 sec as the panel is right by the door.
many thanks for your continued help
yes pal what i want to do is program2 for zone6 only so it could be set all day unless im in there
got to take the kids to a party tomorrow (what fun)
if its easy would i be able to follow your instruction ?
then i wouldnt need to keep you and could do it when i get home next weekend
no rush then and i wouldnt be putting on you
many thanks
Contact me to sort out program 2. In the meantime, simply set the system and omit all the zones except the 'mancave'
CD.
Thanks for all the pointers on this. I have just got round to sorting it. I have taken a real easy way and I just activate the chime on the circuit and switch it off before I go to the man cave 😃😃😃😃
Once again thanks for all the help.
