Hello,
I have a digicom connected to a accenta G4 mini via the communicator outputs When the alarm first triggers it sends a channel 3 like normal, however after the bell time of 3 minutes the systems rearms, I then triggered another detector but it doesn't re trigger the digi this is beacuse the output stays at 0v until the panel is unset then it returns to 12v. I think this is a bit bad as if you cant get back to reset your alarm for 2 weeks you will never know if its triggered again. I tried connecting it to the bell negative this is marked as B on the panel. However it doesn't trigger the digi. There is no external bell connected would this stop it triggering the input.
Thanks for your help
