Accenta Mini inhibit? Zone not triggering
9 Sep 2013
Hi folks,
I'm sure this is a nice easy one for the engineers and those who know this panel well.
Zone 7 on my system used to be a shock sensor on a single glazed pantry window. We've since had a wrap round extension built a couple of years ago, the window plastered over and the sensor removed. This was never linked out on the panel. Today I've fitted a door contact to the pantry door in lieu of the old shock sensor, a little OTT perhaps but there's a safe in the pantry, an auto dialler with no tamper and also and you can access the door on the timed entr route. I've connected this to zone 7 and wired in the tamper et al. Seemingly all is well because I've tested this on chime and it triggers. However, zone 7 does not trigger when the alarm is set. I can open and close the door without consequence. I am no alarm engineer but no zones are omitted as far as I can see. Do I look at systems flags?
I'm sure this is very easy to put right if somebody can point me in the right direction. Thanks in advance.
Check that the zone is included in program 1 in eng menu
Thanks for this!
Must have skipped past in the engineer's manual but now found. Looks like the zone had indeed been disabled when the window was boarded up and plastered.
Now fixed. Thank you.
