Accenta reset not working
29 Aug 2006
Manchester
Hi, I have tried to reset an accenta panel because the old user has changed user and engineer codes.
I have tried the reset sequence, shorting out the set and Tamp terminals and powering up, but it isnt working.
And whats happening is the tamper light is staying on, even when the lid is screwed back. It wasnt on before I started.
Any ideas?
You are in the wrong forum mate.
You should have put this in the ALARMS forum.
Lets see if the mods can move you...
how old is the accenta ? as some versions the factory reset procedure was to to press reset reset within 5 sec of power up. the other way is to remove the pa link or wires connected to the pa fit a link from set+ to one side of the pa zone and re power up.
Any ideas?
place a link between set+ and the right terminal of the pa close all tamper springs then power up with battery then remove power remove link and power up code should now be 0123
