    Dismiss Notice
Accidently skimmed over bracket holes!
Discussion in 'Plastering and Rendering' started by zenonithus, 1 Nov 2018.
  1. zenonithus
    zenonithus
    15 May 2016
    289
    Thanks Received:
    2
    Country:
    I forgot to leave screws in the bracket holes for radiator and blinds. Just wondering if there are any techniques for locating them? I can either scrape off the skim or redrill the holes. More inclined to scrape off the skim.
  2. roughcaster
    roughcaster
    2 Aug 2007
    4,678
    Thanks Received:
    604
    Moray
    Country:
    No easy way if you've filled them in. I normally take the screws out, and put a rolled up piece of paper in the holes.
  3. zenonithus
    zenonithus
    15 May 2016
    289
    Thanks Received:
    2
    Country:
    yeah thought so. looks like I need to start scraping :(
  4. jonbey
    jonbey
    17 May 2012
    1,851
    Thanks Received:
    80
    Essex
    Country:
    is the skim dry already? if not, then where the holes are should be a little darker (still drying) and easy to locate ...
    my builders did this on a ceiling that had 6 downlighters ... luckily the holes appeared when drying!
  5. zenonithus
    zenonithus
    15 May 2016
    289
    Thanks Received:
    2
    Country:
    I think it's all dry now in those areas, though good point I will look out for that in future if it happens again :D
  6. garyo
    garyo
    11 Apr 2006
    1,780
    Thanks Received:
    163
    Berkshire
    Country:
    Try misting it with water and if you're luck they'll show up at some stage in the drying.
    • Like Like x 1
  7. zenonithus
    zenonithus
    15 May 2016
    289
    Thanks Received:
    2
    Country:
    I tried it garyo though no joy. I might actually roughly work out where one screwhole is by taking the skim off and work out the other from the indents in the bracket. I think the work trying to measure up and drill these holes again would take longer than finding the original holes.
Loading...
Share This Page
