Aco drain
22 Nov 2020
Hi
Just had an aco drain installed - its open at both ends, the landscaper telling me that "it doesnt need capping since it will drain out the open end"
Is this standard?
He has put a proper drop on it down to the open end.
It would normally have an outlet opened in the base and put ontop of a trap.
If the water runs out of the end there isn’t much point in it being there.
Where it runs out, they dug a hole, and filled with gravel saying it was a soak away
With pipework in between? A Soakaway wants to be 5Mtrs from a building and you would want a trap to catch any silts.
Disappointingly not.. I actually went with a more expensive quote as the bloke sounded like he knew a lot about drainage
The Aco is still 7inches below the DPC (not the 8 inches I asked for but I let it slide), and hence so is the soak away.
Soak away is next to the house though.. do i need to put a corner on it and run it 5m away? 3m is about the best I could do before reaching the pavement...
I did the same with my driveway and ended up with cowboys that fitted an ACO that the surface water doesn’t even run into. And I do drains for a living :mad:
I’d see how it performs but rather than put a corner on it I’d put a bottom outlet onto it then pipe it from there to a soakaway as far from the building as you can.
To reduce dampness on the wall (or so I was told)
