This is my heating system as best as I can describe it:
It uses a glow worm space saver mark 2 boiler providing heating to 10 radiators ( all trv ) and hot water to a cylinder. The system is fully pumped and uses 2 two port motorised valves. I believe the temp of the radiators is currently controlled by the boiler, the HW is controlled by a cylinder stat. It also uses a drayton lifestylelp522 to control timing. I can have HW independent from CH, but must have HW on to get CH.From reading on the net this means I have a 'S' plan system???
I would like to add a drayton digistat+rf601 to my system.
The timer controller is next to the HW cylinder in a separate room from the boiler. From reading on the net I need to interrupt the call for heat from the controller to the central heating valve. Is this the correct way to go about this? is there a better way.
By the way I plan to put the room stat in the hall and turn the trv onto full.
Other questions I would be pleased if someone could answer are:
How old is my boiler?
Can I still get a manual for it?
