Hi all,
I collect rainwater in a couple of IBC containers and use it for my micro irrigation system. Water is pumped through the system by a Karcher GP40 3.5 Bar pump, rated at 650W.
At present I have to switch it on manually, however am considering the best way to have it automatically kick in when a tap is opened and water starts flowing.
I was considering adding a flow switch of these into the pipework from the IBC containers:
https://www.ebay.co.uk/itm/AC-220V-...netic-Water-Flow-Switch-w-Sensor/303310410726
Specs:
Material:ABS/Plastic
Color:Black
No standby power requirement
Simple installation and adjustment
Self-Clean Function
Screw diameter: 22mm
Contact Form:A
Max Contact Rating:10W
Max Switching Voltage:220V
Min Breakdown Voltage:200 VDC
Max switching current:3.0 A
As you can see the max switching current is 3.0A (I calculate the 650W pump's current to be 2.82A at 230V, or 2.95A at 220V). However it also says the Max contact rating is 10W?
I am wondering if this would be suitable to use, or whether I would need to add a relay to be safe?
Thanks,
G
Specs:
Color:Black
Self-Clean Function
Contact Form:A
Thanks,
G
