ADDING A NEW RAD
25 Feb 2006
how would i add a new rad to my existing system i would like to fit in the hallway its the pipe work i cant understand can i fit the 15 mm flow to any other 15 mm flow and the same with return.
what you need to do is measure up the lenght of 15mm then double it
if its a ground floor rad and there is no other rads nearby you can tap into you will need to drop it from the ceiling the 15mm to the new rad.
under the floor boards you need to trace the other flow and return that leads to an upstairs rad and tap into those i think..........................
