adding a radiator
30 Nov 2010
Lancashire
The exisitng radiators downstairs are on 10mm plastic, I want to add a new rad using 15mm plastic insulated as it goes into the converted garage underground.
I cannot seem to find a 10x10x15 tee so should a reduce to 10mm before the tee?
Think I should wait till summer :(
Why would you take a 15mm branch off a 10mm pipe :roll:
This must be a wind up!!
I was advised that running 10mm over any distance was not a great idea, and i need to go at leat 7meters from the junction to the radiator.
Honest not a wind up, any help appreciated.
Cheers
Unless Both rads are VERY small it will not work.
The larger pipe needs to be before the branch.
Thanks for the reply, so here goes...
1300 double and a 600 double downstairs both connect to 10mm copper at the bottom of the combi, not sure how or if I can add another rad to this system. Go the usual 4 radiators upstairs of various sizes.
My problem I thought was the distance, but now looks like the size of the pipes and the age of the combi, I know it needs replacing as its 10years old.
The gas board hate it im sure,
Cheers
