Adding a resistor to a lighting circuit
13 Mar 2010
London
I have a bathroom lighting circuit with four 10 watt LED lamps.
The dimming pack will not work with this load, ( Nothing lights up) though it does if I add a filament lamp.
I want to try adding a resistor to the circuit, but wonder about the best way to do this i.e location and installation.
Any guidance appreciated.
Do you know what a resistor will do if you add it?
Forget a resistor and change your dimmer.
Or better still get rid of the dimmer. Why on earth do you want a dimmer in a bathroom? Don't you like to see what you are doing when washing, shaving, or toileting?
Those are not the only activities that can take place in a bathroom ;)
Perhaps because he has the intelligence to be able to adjust the brightness to whatever is appropriate for what he is doing?
Sounds like he has a dimming PACK rather than a easy to change dimmer, most manufacturers sell a resistive load accessory that you connect back at the actual Dimmer box.
https://www.mr-resistor.co.uk/item.aspx?i=10031
Hmm. Seems to me that having a large resistance load rather eliminates the low energy advantages of LED lighting. he may as well shove the halogens back in and COR.
It is a dimming pack, and a V pro (Very good yes) would not be suitable as its a period dome type switch, so I needed to install a retractive toggle switch into the dome, dimmed by a dimming pack.
I spoke with the manufacturers about the issue with the pack not working with the load, and they said they would send me a resistor to install.
I have never install a resistor like this before so wanted to get a bit of advice about how other people have done it, but...
Turns out its as 333Rocky333 posted (Thank you). A potted resistive load with leads, so nice and straight forward to install. I was more concerned about enclosing the resistor.
Dimming bathroom lights, Im suprised some find this practice unusual. Most customers I find, especially women like to have a long relaxing soak in the bath, with subtle lighting.
It will probably need cooling air flow as
https://www.mr-resistor.co.uk/item.aspx?i=10031 said:
The RESLOAD has an effective load of 10W and an operating temperature of approximately 40°C above ambient. It should not be covered by insulating materials or positioned near any heat sources or heat sensitive objects.
The resistor shown in the image of a resistor on a heat sink is a 50 watt device 5600 ohms and hence more than capable of handling 240 volts RMS mains
