Currently I have 3 single sockets in the lounge, not particularly helpful with TV, router, printer (odd I know), XBOX, set top box etc.
So I'm looking to add 3 double sockets.
Before I start, I just want to check that my understanding is correct.
1) Adding sockets into a ring main requires no planning permission / notification (it's not a kitchen or bathroom).
2) The "better" way would be to extend the ring main as you can only add 1 spur to each socket and these sockets are wired behind the plaster so makes this tricky.
3) There is no limit on junction boxes, so I propose to cut the cable in 2. Wire one end of the existing cable into the junction box, then from that junction box to new socket1, then wire from socket 1 to socket 2, then socket 2 to socket 3 and then join up new circuit with the existing circuit by another junction box.
4) Junction boxes can;t be left hanging, so need mounting. Is mounting to a roof joist acceptable?
So that's how I plan to do it. The issue is there are 3 circuits coming out of the fuse box and it's not clear which one is which. I propose turning it all off, cutting one of the cables, sheathing it and taping the 3 connections on both bits of the cut. I can then turn the electricity back on and work out which circuit it is I've cut - once I've done that, I could use a junction box to rejoin them and write on it which circuit for future use. The 3 circuits are sockets, lights and kitchen sockets. I can probably eliminate the kitchen sockets by where the cables go so should be 50:50 chance!
My worry is that I read the maximum distance is 100m per circuit and I'm worried this may take it over. I live in a 2bed flat so it's not huge but I have no idea how long the current cabling is!!!
Any comments much appreciated!
Graham
Graham
