I'm looking at installing underfloor insulation:
1930s red-brick house
Suspended floor with crawl space
Good air brick ventilation
100mm depth floor joists
My intention is to use a combination of Rockwool and recycled plastic loft insulation.
The simplest/easiest option would be to use 100mm thickness between joists supported by netting. Would only 100mm be worthwhile? The latest regs suggest 170mm, I think. What would be the difference in benefit in reality?
Or, I could use 200mm of insulation that would be 'bulging' out below the joists.
Alternatively, I could use 100mm and add a second layer of 100mm across the joists. This would cover the bottom of the joists. Could covering the joists cause future problems with moisture?
Any advice would be gratefully received.
