Additional sockets
11 Mar 2002
I want to run a spur off the ring main via an existing socket- how many further sockets can i run off this please
On each spur you can on the ring will give you a maximum of one double socket using no more than 13amp rated appliances. You can have upto 2 spurs per section of ring ( ie if you have a socket connected to ring you can only use two spurs between that and the next joining of two ring cables...hope this helps.
