Hi Guys and gals
I will be fitting a central heating system. The problem is, I will be using a 22mm ring main with 10mm drops to the radiator. this is all in plastic. Now. Which is better using the plastic pipe fittings or using inserts and using compression fittings. The 10mm pipe will be buried in the wall.
