Advice About Making Good Plaster Around New Windows
15 Dec 2007
Bristol
I'm helping my father put in some new windows. When he was pulling the old wooden windows out, the plaster in some areas on the reveals near the windows came away. The plaster that's missing is approx 3mm deep. I don't want to use filler, as the results on medium/largeish areas aren't usually very good.
1) What's the best plaster to buy to repair? Hopefully something that's available in smallish quantities.
2) What's the best tool for applying the plaster to small areas? A standard trowel may be overkill - is a smaller version available?
Any advice would be appreciated.
View media item 68113
View media item 68114
How about a plastic trim to cover all the way around the window? Can look nice and neat when sealed properly, and will hide any other little bits of damage around the window...
Thanks for your replies.
The photos show the smaller damaged areas. There are a few more that would certainly be too big for plastic trims, so will need to fill.
One area is 150mm x 400mm. Would Easy Fill still be OK for this, or would something different be advisable? It says that Easy Fill is a joint filler. The damaged areas are certainly bigger than joints.
Wickes plasterboard adhesive/filler works a treat and in cheap as chips. Loads better than easi-fill at a fraction of the cost.
Just use patching plaster. Available at any of the DIY sheds. In fact I think some even sell ready mixed tub stuff. If there are enough damaged areas for it to be worthwhile, I'd also invest in a plasterers float, you will get a better finish than just using a filling knife or similar.
