Advice - First Fix Ring main or Radial?
Not sure if its fridge freezer will need its own curcuit tbh.
The kitchen is the longest run as well as it's the opposite end of the CU in the extension.
I will be leaving 900mm gap (think that's enough?) at end of units for tenant to supply their own.
Oh, it not for your own personal use!
A faulty appliance can easily trip a kitchen circuit RCBO, and for the inexperienced, take hours/days to get back on - which was why I suggested, and installed a separate fridge/freezer circuit.
What do u do the the x2 smoke alarms and heat alarm guys?
Own feed or tap off lighting??
I like a separate circuit, with the an alarm which bleeps, to warn of a loss of power. John likes alarms on lighting circuits, so if the lighting circuit fails, you are more likely to notice the loss.
It's one of my rentals mate.
I'm gutting the place as it's not been done for years.
Needs EiCR etc. plus in Wales it's also mandatory to have interlinked mains battery back up smoke alarms upstairs and downstairs.
I always fit AICO.
