I want to remove walls between kitchen and lounge, structural engineer could not visually work out if the walls are load-bearing as all walls in the flat are solid walls. (it's a concrete purposed build building).
He suggested to remove finishes to underside of ceiling back to underside of concrete to see if Precast plank joints exist. The area needs to be opened up are 3m x 0.5m on the ceiling of both side of the wall. What tool is best for the job? Angle grinder with SDS drill?
Structure engineer said it should be 1-2 inches thick, how do I know when to stop when it hits the slap or joist as they are all concrete?
thanks in advance.
thanks in advance.
