That B&Q sliding mitre saw with 210mm blade has a depth stop which allows you to cut housings although the blade doesn't reach full depth at the back of the slide unless the stop isnt used.
A bit of 2" (50mm) wood against the fence should allow a full depth housing over 6".
I found mine usefull for cutting tenons once I realised its limitations.
