advice on fitting suite - picture
your toilet overflow cut off and get rid of. all new toilets have internal overflow - low level or close couple.
your bath taps why don't you keep the copper and just replace fibre washer in the top - better than flexis.
your toilet feed cut and use a end feed 15mm coupler to join new pipe then a 90 degree bend up to a service valve joining the cistern
and if that was me and you plan to keep your cistern and basin pipework exposed i would have it in chrome 15mm pipe
Many thanks.
Going to give it a go - can always call out emergency plumber!!
Cheers
Rich
