Hi guys just thought i would get the experts advise on some simple water related query, New kitchen coming in on the 8th May, Gas man is out on the 6th to cut gas supply to remove remainder of units,
I have a slight problem with my water, I need to move "well I think I do " my stop cock slightly to the left of original position as sink is moving over and washing machine is going to be in place of existing under sink piping.
with the new position of sink, My hot water pipe will also have to be looked at. I would also like to install out outside tap coming from the same point. Pictures to follow.
What would your view be on this, i.e. how easy to complete and tricky issues I need to think about, should I use existing pipe work or start fresh.
Hope you can give me some advise
you fine peeps
Thanks Dean
Pictures.
Existing unit, washing machine and under sink piping.
New drawing of kitchen unit, washing position, and new sink position.
existing under sink pipe work. to be reorganised and moved
existing pipe work and water inlet under units and hot water pipe at back of unit
you fine peeps
Thanks Dean
Pictures.
