Hi I'm looking for a bit of advice. We live in a Victorian terrace and have a small (narrow but long) back yard which is covered by a layer of concrete (about 8 to 10cm thick). This slopes markedly towards the house and bridges any damp course by at least 20cm at the highest point (the level of the concrete in the garden is considerably higher than the level of the floor inside the house) and has caused damp problems in the past. The concrete also looks a mess.
We're now thinking of putting some slabs down in the garden but don't wan't to raise the ground level further and really would like it level, as such I'm thinking of digging out the concrete. I'm wondering if this is wise though - one tradesman had suggested that due to the age of the house the concrete might now be partly supporting the walls and removing it could cause problems, is this likely? If I do remove the concrete should I think about installing a french drain or something similar or would it just be sufficient to the let the water drain through the slabs. Are there any other important points I need to think about before starting. Thanks very much, I've included a few pictures just in case these help.
[actually I've completely failed to insert any images - here are the URLs instead:
http://imageshack.us/photo/my-images/641/photo2xw.jpg
http://imageshack.us/photo/my-images/217/gardenconcrete.jpg/
