Hi
Refitting main bathroom and adding power shower (with body jets). Second bathroom (for the kids) already has a powered shower, so am upgrading existing pump to run both rooms (as existing pump is old and noisy anyway).
Here is a pic. Fitting new salamander ESP 100 and they state dedicated HW supply from surrey or essex flange. I know I should follow MI but presume this will mean fitting two of said fixing and drawing off a joining pipe. Was hoping to just draw off existing Tee (upgraded to 22mm) before reading the small print.
Any hope of not increasing the amount of work...
tanks have separate CW feeds and there are two outlets, one you can see leading down from the white painted 45deg vent pipe, the other is off the back of the criss cross of pipes that link the top of the two tanks. current pump source Tee to white 15mm plastic.
