I have to plumb a washing machine into a utlity room that has no easy access to the waste water drain. So, I have to run a waste pipe along the outside of the house for approximately 20 metres to get to the gulley. (I have to run the water supply like this as well so will put both in some sort of trunking so that I can insulate and protect).
Worse, this pipe will have to be virtually at ground level as it has to run around a conservatory (walls only about 1 foot high) so there is no chance of any incline.
The only solution I can think of is a waste pump (saniflo etc).
My questions:
My questions:
- They all seem to be mascerators and I don't really need that. Are there any that are just pumps?
- Will the lack of gravity drop on the long pipework be a problem?
- Any other solutions?!
