So i was sort of right in thinking that if it just kept heating up and you switched this valve he's thinking of fitting, it will just keep venting into the loft?
if you stop the water circulating as in a valve or what ever, the boiler won't fire up after the boiler stat cuts out cause the waters not leaving the boiler and coler water returning to keep the boiler stat low etc.
