Hey Guys,
Just looking for a little advice please, so i have bought and installed a Yale wireless Telecommunications Alarm at my home.
I know that the professional systems are better etc but is what i went for just for a little peace of mind.
So i have installed 3 PIR's in my home (Ground Floor Masonite) however and doing a bit more research after installation
It seems that i have not put two of the PIR's in the right places.
Just looking for some advice on whether or not i should move them?
1. Kitchen
As you can see by the layout i have the PIR facing a window in the current South West position and what i have read online is that this can cause issues, i would just like to note that when ever the Alarm is armed i always close all curtains and blinds and i live on a ground floor and i never like to show what i own to anyone looking in .
All of the other corner positions in this room are obstructed by Cupboards and the one that is not has the boiler in it.
I could put the PIR above the window but this will then pick up the Door Contact on the back door (PVC Door with Window), again i have read this is a no no?
What should i do guys? bearing in mind i have the blind down when the alarm is active. Keep the PIR here or move it?
2. Hall way
My only concern here is the PIR in its current position is picking up the front door (PVC Window With Door Contact) and the window next to it.
I could move the PIR to above the Front Door, should i do that or keep it in current position?
As i said guys just looking for advice im trying to keep the False alarms to a minimum but also want the optimal coverage.
Thanks to anyone that posts
Regards
Edit: I have uploaded some pic layouts of the two rooms, hope you can see them
1. Kitchen
2. Hall way
Regards
