aeg L12710VIT dryer fault
3 Jan 2011
Bedfordshire
When using the wash and dry cycle (which we use every 3 days) the clothes are still coming out damp. We have have used this cycle for nearly 2 years with no problems.
It appears that when the cycle finishes the clothes are very hot and damp. I am no expert but its like the condensor isnt draining the water away and therefore the clothes are still damp. If that make sense?
Is there anything we can try before we call someone out.
Thanks in advance
Grant
It could be a clogged condenser, defective pump etc. But to pin down which particular machine you have you need to post the PNC number on the door sticker. There are several different versions of this model.
Thx for the reply zipper. Had someone come and look at it today. It was a faulty Valve. It has been replaced and he also cleared out the condensor. Hopefully everything will run smoothly now.
