- Joined
- 19 May 2009
- Messages
- 18
- Reaction score
- 0
- Country
I have a AEG Lavamat turbo L14850 and the door handle is broken. (Very common I understand!) We have called out a local AEG specialist repairman from Aberdeen and he replaced the handle.
The only problem is that the washing machine will no longer start until you push the door in very firmly at the handle. It will then start. Problem is the machine will not open at the end of the cycle. We eventually managed to get the door open and called them back.
The answer coming back is that they are ordering a new trim (the bit of plastic round the front of the door on the outside)
I simply cannot understand hgow this will fix the problem!!
The door was opening and closing firmly before he fiited the new handle. Now apparently we need to modify the door??? (At great cost!)
Is this correct?
Is this correct?
