this morning on opening the hot water tap i found it had lot of air.
1. so i left the the tap running for a while and then closed and left for work Is it ok to run the tap to clear as there was fair amount of air
2.there is an air bleed vent pipe with a black screw with a hole near the cylinder. when ever there is air should i use the air bleed manually OR in what position should this black cap be left in i mean should it eft open at all times or it should be closed at all times and used only when air lock in cylinder.
any help and comments will be appreciated
thanks ih
thanks ih
