I have a Bungalow with a suspended floor, built around early 2000's, I was getting a musty smell in my daughters bedroom, done some investigation and found that the air bricks outside where blocked internally, what I mean by that is that I went outside and poked a stick through the air brick , this would only go so far then hit something hard, I went under the floorboards and found concrete pretty much covering the vent on the inside, I then checked some of the other vents outside and found the same with more than half. Im planning to drill out any airbrick which is. blocked. This issue looks like its been intentional, to purposely block the inside, allowing some but a lot less circulation, the guy who originally built the house is a bricklayer, so you would think he would no what he is doing. Does anyone know why this would be done like this and would you suggest drilling them all out. many thanks C
