We moved house in the summer and obviously now are using the central heating. However I find we need to bleed the radiators every week - and when the system is on you can sometimes hear the air going through the pipes, radiators and gurgling in the pump.
I've done a search and found lots about hydrogen. I've tested for this and its not.
Its a vented system, the pump is on the flow pipe, just before the mis-position valve. The problem does not seem to happen when on the hot water only so I suspect the problem is not the pump, valve or boiler.
Can anyone provide any advice on how to do some fault finding before I call in a heating engineer to fix it. This is driving me mad now and would love to get it fixed.
Many Thanks
lg
Many Thanks
lg
