air in rads
5 Mar 2005
fitted trvs on open vented system when i refilled system had trouble removing air from rads ,got it done in the end but every other day the rads need bleeding do i need to bleed the pump, which is set on no 3 any advice ? :oops:
Turn your pump down. You are probably sucking air in through the vent pipe.
joe
