I have an unvented hot water/heating system. The system come with the house, which are both just over 3 years old. Every summer, when it is warm, I always have problem with the heating. Either going off completely or a while ago, the pump would not stop in accordance with the timer. I have sought the advice here and apparently the PCB of my Potteron is sh*t. However, as it is working most of the time and it cost so much for the PCB, I thought I just leave it. (Not to mention a thread recently on the problem of blewing fuses after a new PCB.)
Another problem is air getting into the system. Whenever the heating come on, there is a lot of bangs near the boiler and/or the pipes. Which is pretty scary. I have tried to let the air out from the radiators and letting more water into the system - through a double valves control near the hot water tank. This used to do the trick. However, it doesn't work this year. The bangs keep coming back and I have let in a lot of water already. I cannot see any obvious leak apart from some seepage near the mains, near the hot water tank. Any idea where the water has gone and how can I trace it?
Somehow, it wasn't a problem in the winter when the heating is on all the time. Only when the themo-control cut it that I have so many problems.
Many thanks in advance.
