Hello,
I have a question which hopefully you guys will have a logical answer to!
I moved into the house six months ago. The oil-fired, vented central heating system is about twenty years old and I plan to potentially replace it with gas this summer, but it's working fine for the time being.
I'm aware of the various causes of air in the system and in the last six months I've had to bleed the bedroom radiator (the highest one, I would guess) only twice, and none of the others ever have air in them. It's not a big problem but my question is as follows:
The pump makes a rushing sound every 5-10 minutes or so when it's running, but it's fairly quiet otherwise. This suggests the air bubbles are surfing round in a group when I would expect them to get caught as they float to the top of the first radiator they come to.
I've searched online and in these forums for the answer to this but can't see any similar questions, so apologies if it has already been discussed. Basically, physics would suggest that the bubbles should float to the first radiator they come to rather than continue round the system repeatedly until finally settling in the highest radiator.
(the alternative explanation is that the highest radiator is also the first one next to the pump and the air is being drawn down the overflow and then going straight into that radiator every few minutes, the cycle being coincidence).
Cheers,
Chris
Cheers,
Chris
