Hi guys,
This topic must have been discussed a lot but I can't find anything specifically answering my question, so hopefully you boys can help me out.
I've just moved into a house which has a brand new (one month old) oil fired combi boiler with a built-in expansion vessel, connected to a very old central heating system. One new radiator was installed along with the boiler.
The highest radiator in the house was full of air when we moved in (there was about an inch of hot at the bottom, the rest stone cold) so I bled it and all was good. Unfortunately the air returns after 3-4 days.
When the central heating turns on, which it does frequently because the house has poor insulation, there is a loud purring in the pipes which seems to start near the boiler, then can be heard following the central heating loop round into the living room and then finally upstairs into the bedroom where the radiator in question is. It's very noisy but after a minute or so it's quiet and the system runs as normal. After the heating goes off for a time then comes back on again, the same thing happens.
So how do I tell if air is getting in or if it's gas? It seems like a lot of gas to be produced in a short time and it seems that there was inhibitor introduced into the system a month ago. The system pressure is good at 1-1.5 bar and isn't going down. If it's air, how could it be getting in so fast? There are no leaks that I can see.
Thanks for any input! The house is rented so we can't call an expert in ourselves and have to have a good reason to get the landlord to do it.
Cheers,
Chris
Cheers,
Chris
