Airing cupboard help
  • Thread starter Thread starter harrisonline
  • Start date Start date
H
harrisonline
My 3 year old son got to our hot water tank and turned some of the red taps.
The problem I have is that I am not sure if they should be in the open or closed possition.
I have a feeling that one was open and the other was closed. He couldn't reach the third tap.
I have since fitted a bolt to the door.
I have taken a photo of the system and taps and can e-mail it to anyone who would like to have a look for me. To see if you know what taps are what?
Thanks for your time.
They should probably all be open. If your feet get wet that I take that back.
You can email me and I'll stick them up for you, or you can use something like Photobucket, which is worth getting to know.
Maybe your son knows how to do it? :P
Thanks.
I have e-mailed you a photo.
I will learn about photo bucket in case I need to post some more photos.
Are the two blued pipes connected? If so the rear valve is a bypass and in your case can be shut as long as you don't have thermostatic rad valves on every radiator in the house.
Front one we can't tell, but is probably a tap water supply pipe which needs to be open. (open full and close half a turn so it doesn't seize)
Yes the 2 pipes you have highlighted are connected.
Have I done any harm in opening and closing the tap?
Nope, none at all.
The valves can weep a bit from their stem seals when they're turned, you could check for that and nip up the nut round the stem if reqd.
Turning those nuts up tight would stop vandals and hooligans turning the handles!
(or undo the small nuts holding the handles on and the handles will slide off - tie on string high up!)
Any chance of employing your 3 year old - everytime I go to a domestic gate valve they are seized after years on not being used!
If it can be turned, opened, taken apart or broken he'll find a way!
