Hi there,
I got called out to a system boiler, it will fire up for say 30 seconds then cuts out. The boiler makes all sorts of noises. I have checked the flow to the cylinder which gets hot, but the return is cold plus cylinder. No fault codes on the boiler. It only has one large header tank. Is it a primatic cylinder and if si is the dome knackered. These syptoms happen on dhw and ch.
Help would be appreciated.
cheers
cheers
