I have a Gardtec 500 Series system, which I don't use, but it's been sitting here doing nothing for the past five years. Tonight the external bell box sounded off out of the blue, for quite a long time (probably about 15 mins), but there was nothing happening inside the flat, no buzzer, etc. The setting panel shows "Un", which I imagine means it is "unset".
The bell box is a plain opaque white plastic cover, a sort of triangular shape with bottom two corners squared off, no visible name. There are red lights flashing in both the bottom corners now.
Does the fact that only the external bell sounded suggest that the battery in there needs relacing, or is it likely to be something more sinister?
If it's the battery, is it a straighforward job to replace, or will I need to call out an engineer.
There was no handbook here when I bought the flat, but I was given the setting code. I've checked out a handbook online, but it doesn't say anything about this problem.
Thanks in advance for help folks.
