Alarm set
26 Feb 2013
Staffordshire
Hi ive recently moved in a new house and have the C&k securitech co23-203 iss.1 how to I activate night mode???
Just realised we don't think it's working just done exit mode and listened through door and its doing a buzz tht doesn't go off
it probably needs resetting code and # to reset, if 8 still flashing look for a panic button it may need resetting, to night set press code * 0.
Hi resetting hasn't made a difference still bleeps on exit, and number 8 flashes any other ideas?
Number 8 flashing yes while unset and when I try set to exit it's just beeping constantly doesn't go off like a normal alarm
After vacating house
it must be a panic button check bedrooms side of beds and front and back door for panic button, or try code * 8 this may force isolate the zone on setting you will need to do this every time you set system.
Thanks ill try this how come when we leave the property the alarm just continue beeps and doesn't set
because zone 8 is still open ! ! ! open control panel box ( a4 sized metal box ) remove wires in zone 8 and fit a link of wire to short out zone 8.
I don't think a woman should b messing with wires lol the control box is tiny about small envelope size
