Got a bit of a weird one...
All the socket outlets (bar two) have only one cable going into them. This is the case for both upstairs and downstairs. The two exceptions are in the dining room and, lifting a loose floorboard, I can see these two are connected with the other cable running off to the two other sockets in the room.
One of the sockets in one of the bedrooms has also been replaced with a four socket extension lead which has been connected into the circuit under the floorboards.
I have checked the CU and the 2 MCBs having two phase conductors running into each of them as if they were ring circuits.
The downstairs circuit supplies a hall socket, 4 sockets in the lounge and 4 sockets in the dining room. The upstairs circuit supplies 4 sockets in one bedroom, one socket plus the extension lead in the other bedroom.
The problem I have is that the socket and extension lead in the 2nd bedroom have stopped working so I found all the above from my investigations into why.
It came up in the survey that the wiring needed to be replaced as it is very old - has anyone come across an old way of wiring sockets that could explain this? Could there possibly be one loop with all sockets connected as spurs through junction boxes? I would rather not start pulling up carpet and lifting boards so thought I would try here first for any help.
