Been doing some decorating/renovating in preperation for a new arrival, and as part of the job i replaced a radiator.
The system was drained down, the old rad removed, and the pipes capped off while plastering and other work was done. System was refilled and ran fine during this time, though i thaught it might have been a little noisier than before. A sort of watery rushing type sound. But there was a hole in the floor with the pipes exposed etc, so i figured it was just that.
Last week, i drained the system again, installed the new rad with new valves, and got it all refilled with a bottle of inhibitor. Rebled it again a few times to get all the air out and making sure it was filled up to the right pressure again.
The noise however has now got a lot worse. It seems to be worse after the burners been running for a while, it sort of builds up, starting as the same watery rushing noise, but getting louder and turning more into a drone at random times. At its worst you can literally hear the pipes vibrating/buzzing in the walls. It doesnt last long though, appears to fade away again if you ignore it. I will try to record the noise, but not sure if i can capture it.
At first i thought it was a balancing issue having disturbed things, but i tried turning the new rad on and off when the noise was at its worst, and it makes no difference.
I think the noise is actually coming from the boiler itself, when its running theres a distinctive vibration from the boiler and the pipework, and if you turn the boiler thermostat down such that the burner shuts off when its vibrating at its worst the noise immediately stops, despite the fact that the pump is still running etc.
Any ideas? I'm wondering if the draining down and refilling has dislodged some crap which has ended up partially blocking the heat exchanger :/
