Hi Think i have the same problem as a few others previously. The C/H is fine as soon as i turn the hot water on it cuts out. If i try just the hot water it does not fire up. Sometimes with the C/H on and if i turn the hot water on it will keep on cutting in and out. I have read some previous posts about this problem and the problems seems to be either the DHW Diaphragm or the diverter valve. I took a look the other day and noticed the shaft on the DHW come out although did not check it was activating the micro switch. Would i be right in thinking if i operate this manually and it cuts in then its the diaphragm, of course making sure the switch is ok. How would i check the diverter ?
