I was looking to install a Nest thermostat and started trying to understand the existing wiring to work out how to add. The boiler is an Alpha CD20S and is currently set up (in my limited understanding) in a S plan configuration (2 valves rather than 1) as part of a pressurised hot water system with a megaflow style cylinder (different brand). The existing thermostat is a salus RT500RF, which is wired into the system using a Salus TC100 wiring centre.
My question is this... according to the boiler manual if a thermostat is used the boiler should be fed with a continuous mains feed, and then the thermostat should operate a switched live feed to turn the boiler on.
However when I was tracing the wiring it was obvious that it had been installed such that the mains feed is being turned on and off itself. i.e. when the thermostat is off the boiler receives no power whatsoever. This has been like this since we had the boiler installed a couple of years ago but is this an issue? My limited googling suggested that e.g. the boiler might want to run a pump or similar after the gas has been turned off to draw off excess heat. How worried should I be or is just a different approach?
Link to boiler manual (page 5 for wiring):
http://www.alpha-innovation.co.uk/custom/upload/instructions/CDS/CD S Inst & Serv Inst 01-11 .pdf
Thanks very much in advance
Simon
Simon
