Hi All, Been through many different posts but not managed to resolve my problem.
After being topped up to 1 bar I need to refill after approximately 7-10 days.
Got an Alpha CD28C with the premierpack, no leaks at the rads, been under the wooden floors and no leaks in the pipework, no air in the system, all radiators working, some very small drips on the floor tiles under the bathroom radiator the odd time (not every day) but wouldn't have thought enough to cause the drop in pressure, no leaks from prv outside, water comes out of the other pipe when the heating is on but have been told that this is condensate and to be expected (as it's a condensing boiler). Have pressed the valve at the expansion vessel, no water just air comes out, so from what i have read this is working ok, when the heating is on pressure remains at approx 1.5-2 bar.
Not sure what else to try, am i able to isolate this boiler from the pipework to see if its the boiler itself or the system, at least this would allow me to narrow it down a bit more.
Water from the system is blueish, is this the inhibitor which would have been added 18 months ago when the new boiler was commissioned?
Thanks.
Thanks.
