can anyone please tell me if the drayton lp111 and honeywell volt free digital room stat are compatible with this boiler as i had them on my old boiler a vokera 24 compact and would like to reuse them if possible, many thanks.
most volt free gear can also be used on mains voltage so it should be compatible, however because I dont do installs I couldnt tell you which connections to use without looking it up, and I cant be arced at the moment.
