I have an Alpha CD50 boiler which is 4.5 years old. It is leaking water from the top of the manifold for the primary pressure switch and the heating pressure relief valve. The leak is quite slow at present, maybe 1 millilitre per hour. The leak is where the pipe is fixed to the manifold.
The qualified installer who fitted it says this joint is sealed with an O ring in the annulus between the pipe and the manifold bore. There's no way the manifold can be moved so to replace the O ring the pipe must be lifted upward - the pipe forks so there are two other joints which need to be released. There are no instructions in the user manual (the 40 page one) for this task. The pipe disappears behind the heating pressure vessel which I assume will have to come out, not sure whether there's anything else to be removed.
Can anyone advise me on what might have to be done and whether this is something I can DiY? I have some plumbing experience and DiY most things.
