Starting from the assumption that the original fit accumulator on my boiler has gone tits up, water from the pressurising valve, then can I fit another accumulator into the return flow side to the boiler. I plan to tee off the return in plastic with a full bore isolating valve before accumulator. I have been reading that there needs to be a check valve prior to the accumulator. If this is right do i have to put the accumulator on a loop rather than a tee and if so what do i need to attach the accumulator to, manifold?, because the ones i see only have the one inlet.
